6/22/2015 7:56 PM | |
Posts: 4 Rating:
Hello, I can not connect to CPU315-2 DP. How I can make the PLC back to factory settings?
Last edited by: Min_Moderator at: 6/23/2015 8:59:39 AMNew subject after splitting |
6/23/2015 10:10 AM | |
Joined: 5/28/2008 Last visit: 9/26/2023 Posts: 4477 Rating:
Hello, Any CPU comes without a memory card. If you removed the memory card from the CPU, then the CPU will be returned to factory settings. (i.e. no software is executed on the CPU) But you have to check your connection (PG interface or PC adapter) and Set PG/PC interface setting to establish communication with CPU. Hope this helps. |
Ayman Elotaify |
6/24/2015 5:24 PM | |
Joined: 8/31/2005 Last visit: 9/14/2023 Posts: 2194 Rating:
https://support.industry.siemens.com/cs/ww/en/view/13008499/24570788363 |
