1/8/2011 10:23 AM | |
Posts: 1064 Rating:
Are you using a switch or cross over cable to connect th eplc to your hmi?? |
1/8/2011 11:09 AM | |
Joined: 9/6/2007 Last visit: 9/19/2023 Posts: 78 Rating:
I don't use switch hub and the cable isn't cross over. Should I do this ? Tks.
1/8/2011 11:25 AM | |
Posts: 1064 Rating:
you should need a switch or cross over cable to connect them , i would use a switch that way you can program with your pg at the same time |
