8/9/2012 10:38 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, The CPU clock should stay o.k. for 60H after power down, unless you messed with time sync settings In CPU properties. If you mean the HMI is showing wrong time: How do you synchronize the date and time between an operator panel and an S7-300/S7-400 controller with WinCC flexible? Regards, Marcjan |
Problem solved? |
