12/29/2009 10:46 AM | |
Joined: 3/18/2009 Last visit: 5/6/2024 Posts: 306 Rating: (94) |
There is only one cyclic interrupt OB available inCPU 316, which is OB35. Hence you are not able to download OB36. Your only option is to either avoid OB36 in your SW or change the CPU. |
1/2/2010 5:48 AM | |
Joined: 7/2/2008 Last visit: 8/26/2024 Posts: 928 Rating: (308) |
Hello haquang, Please check daga's link (CPU 316) again. In technical data tab you would see that number of watchdog interrupts is 1 (OB35). You can switch again to Entries tab and make a filter with manuals instead of all typesso you can find all manualsof this CPU. From the three manuals that are found, you can chose S7-300 Instruction List CPU Specifications CPUs 312 IFM to 318-2 DPwhere you can find the data youwere looking for. I always do my search this way and I hope you find it easy and useful. Best regards. H-H |
1/5/2010 4:39 PM | |
Posts: 3 Rating: (0) |
OK! I've got it! Thanks for all your helps :) |
