3/26/2010 7:34 AM | |
Posts: 7 Rating:
Dear all, I have CPU319-3PN/DP master CPU, on MPI/DP port there r total 63 profibusnode with 2 repeter & on DP port there r total 80 node with3 repeters.On MPI/DP port total 5 CPU as slave available. I need to add2 more node (ET200M)on MPI/DP port. When I added 2 node on this node then there r BF(bus fault)found on 2 slave(node:4&70),other nodesr healthy. When I removeadded 2 node from n/w profibus n/w found ok. systm config. is as per attached sheet. Attachmentconfig.zip (62 Downloads) |
Last edited by: sandy77 at: 3/26/2010 7:52 AMLast edited by: sandy77 at: 3/26/2010 7:50 AMLast edited by: sandy77 at: 3/26/2010 7:50 AM |
