10/16/2010 12:42 PM | |
Joined: 7/28/2010 Last visit: 4/25/2023 Posts: 184 Rating:
Hi, You can do aCross Reference to find where that PW140 has been used in the code and replace it with the new parameter. You can use Rewiring to replace PW140 with new parameter too. Don't forget to make a backup from online code so you can always undo the changes in case there is a problem. Regards, Behnam www.sigmaprocess.ca |
