12/21/2022 9:16 AM | |
Joined: 12/20/2022 Last visit: 12/21/2022 Posts: 5 Rating:
Hi, I'm new to motion in TIA Portal. I'm looking to create an array of axis that would then allow me to access each array features by doing
I found this and I'm trying to apply it : https://cache.industry.siemens.com/dl/files/880/109750880/att_942526/v1/109750880_use_data_type_DB_ANY_en.pdf I created a new DB with an array of DB_ANY, and I can then attribute my technological objects to it like this :
("Axe Z" being my technological object). Then problem then is that if I try to do
it doesn't find any of the sub elements of the axis, I don't get auto completion and it makes an error. I am probably missing something, there probably is something else I need to declare. Could you help me ? Thanks in advance for any answer, have a great day. |
12/21/2022 9:41 AM | |
Joined: 5/12/2006 Last visit: 2/1/2023 Posts: 21216 Rating:
which cpu do you use? Simotion PLC have no DB and also no DB_ANY! |
12/21/2022 11:09 AM | |
Joined: 6/19/2017 Last visit: 1/27/2023 Posts: 6401 Rating:
Closed cause question posted twice. The second thread with the subject Declaring an array of axis is published within the conference SIMATIC Technology. Jen_Moderator |
