12/5/2021 7:39 AM | |
Posts: 1 Rating:
Hello; I would like to create graph overview for HMI. I have wincc run time advanced for this project. I have tried connect to plc tag graph but there is no connect tag for our project. How can i find plc tag to connect our graph programming?? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/06/2021 11:53:51New subject after splitting |
5/11/2022 10:43 PM | |
Joined: 3/1/2018 Last visit: 3/24/2025 Posts: 37 Rating:
You should point to one tag from the instance DB of your GRAPH FB on the GraphOverview component (for example "OFF_SQ"). Therefore, I am not sure if it's possible to use this element in WinCC Advanced, probably only at WinCC Professional as you can see in this example here. |
Last edited by: Jen_Moderator at: 05/12/2022 11:31:31Link optimized. Best Regards, |
5/12/2022 3:00 PM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15338 Rating:
Hello hosgoren01 you can see a lot of informatoin also to WinCC comfort/Advanced in this Basic Application example: https://support.industry.siemens.com/cs/de/en/view/109740151 Bye Murof |
2 thankful Users |
