9/12/2008 5:00 PM | |
Posts: 487 Rating:
See the link below. http://support.automation.siemens.com/WW/view/en/21927773 What is your exact version of OS & WinCC? As per matrix you need Windows 2003 SP1 Standard server OR Windows Server 2003R2 for WinCC 6.2. But if you have WinCC 6.2+SP2 then you need Windows server 2003 R2 SP2 + KB929046 OR Windows server 2003 SP2. Also for WinCC 6.2 SP2, you need downtime monitor V1.0 SP1. |
9/17/2008 1:04 PM | |
Posts: 1776 Rating:
Hi, your versions seems ok. In this case i think you shouldmail to the Wincc hotline |
