6/19/2010 12:41 PM | |
Posts: 43 Rating:
Hi friends, Can any one explain how to assign the softkey by PLC. I am using 840D PCU 50 with S7300 CPU. |
6/19/2010 5:04 PM | |
Joined: 3/25/2008 Last visit: 1/28/2022 Posts: 232 Rating:
Hello there. Sinumerik devices is one topic i have nerver touched before, buy maybe it will isefull for you to know that all information, manuals, FAQ's and updates relatet to Siemens A&D can be found in "Siemens Product Support Home Page". In the left side you will find a tree wich shows you theall product categories, bysearching and then selecting the "right one" for you, you will be able to display all the topics related withthe technologie you are working on. For example for FAQ's about Sinumerik HMI software this will be the right link "HMI SOFTWARE FOR CNC CONTROLS FAQ's" I hope this help's. |
Keep working! |
6/19/2010 6:38 PM | |
Joined: 9/18/2006 Last visit: 3/19/2023 Posts: 583 Rating:
Hi. If I have correctly understood... HMI software creates softkey. You can create the user screens in HMI. Buttons have various levels of access in your screens. From documentation BE1: Access Level Empty Can always be written ac0... ac7 Protection levels (see chapter "Syntax of softkey description") If the access level is not adequate, then the first line is displayed grayed-out, default setting: ac7 You can operate access level to buttons from PLC changing signals keyswitch DB10.DBX56.4-... DB56.DBX56.7. Probably it will help you. Best regards. AttachmentAccess level.pdf (97 Downloads) |
