6/4/2020 12:27 PM | |
Joined: 7/5/2013 Last visit: 4/17/2025 Posts: 3147 Rating:
Hello Rabinio, which application type are you using (Panel, RT Advanced, RT Professional)? Have a look in the following FAQs: - How do you store data with a script in a file with WinCC (TIA Portal) PC Runtime? - With SIMATIC WinCC (TIA Portal) on a panel, how do you access process data in a file via a script? Regards, Frink |
Pi is exactly three! |
6/4/2020 12:45 PM | |
Joined: 1/31/2020 Last visit: 10/11/2022 Posts: 19 Rating:
Hello! I am using WinCC RT Pro v15.1. I am just starting to learn scripts if you have detailed instructions for my situation I will be glad to read. |
6/4/2020 2:15 PM | |
Hello There is no special FAQ for WinCC Professional but one for WinCC Classic. you can use it similar to WInCC Prof. https://support.industry.siemens.com/cs/ww/en/view/850338 Bye Murof |
Last edited by: Murof at: 06/04/2020 14:25:18If this Information really helps, you could use the Rate function |
