2/13/2015 12:23 PM | |
Posts: 26 Rating: (0) |
Hello, what is the function of the hole in the picture? Ground? I can't find its description in the manual. |
2/13/2015 1:09 PM | |
Joined: 5/12/2006 Last visit: 9/24/2024 Posts: 22371 Rating: (3014)
Hello, this is for the shield connection kit. Which Shield Connection Kit can be used for which Control Unit? Regards |
2/13/2015 1:27 PM | |
Thank you. Is it necessary to connect the CU to ground with a dedicated wire if i don't use the part that you showed me? |
