1/19/2021 5:29 AM | |
Joined: 7/30/2016 Last visit: 7/29/2024 Posts: 4 Rating: (0) |
Hi Sir We have same problem in our equipment. The alarms are same with this case, F30611/1951. F30600/9999, F1600/0, the occur frequency is about every month. I have replaced the MM, DriveClicQ cable, CU before seeing your answer. And now, I check the CU firmware, CU320-DP, FW version 4.4.0.4, Control_Unit FW 4402315. Is is same reason with this case? Can I upgrade the V4.4HF23? I just see the upgrade instruction that upgrading process to v4.4 from v4.3, but there is no to V4.4HF23 from V4.4 low version. Thank you very much. Best Regard Xin
Last edited by: Jen_Moderator at: 01/28/2021 12:50:12New subject after splitting |
