9/3/2013 3:06 PM | |
Posts: 1299 Rating:
Hello, |
11/29/2013 8:25 AM | |
Posts: 1299 Rating:
Hello pratik7332, did you see the chapter in manual and tested it? Do you have any precise questions? K!ke |
11/29/2013 11:01 AM | |
Joined: 9/2/2012 Last visit: 12/29/2022 Posts: 711 Rating:
Hello, In my 1st post i have mentioned about WICC PROF, your case is wincc advance which is equivalent to wincc flexible itself. in tia advance recipe features are readly available. regards vipz
11/29/2013 11:21 AM | |
Joined: 11/26/2009 Last visit: 11/22/2022 Posts: 208 Rating:
hi, I am using wincc flexible TIA advanced in which the recipe is readymade available. I want to display the recipe content in different format. i want to display all the data records on the single screen. you can understand by below. Recipe - TEA Elements - Water, milk,sugar,tea powder Recipe - Coffee Elements- Water,milk,sugar,coffee Now i want to display the data records in the following manner. Recipe - TEA Batch Sugar milk sugar Tea powder 1 100 200 50 50 2 50 45 50 40 3 150 50 10 50 I want all this data records should be display simultaneously on runtime. note that the data records are displayed horizontaly. |
11/29/2013 1:27 PM | |
Posts: 1299 Rating:
Hello, what you describe is the recipe view for runtime professional. in runtime advanced there is only displayed one data record at a time. K!ke |
11/29/2013 1:39 PM | |
How can i update advanced to professiona???? |
11/29/2013 2:18 PM | |
Posts: 1299 Rating:
Hello, the question is not how to upgrade, it's what you need. If your runtime system is professional you also need the engineering software wincc professional. but if the runtime system is advanced it doesn't solve your problem to buy a higher version of engineering. Which software is on your runtime system depends on the plant. if your runtime is a "normal" hmi runtime advanced is perfect. if it's a whole scada-system runtime professional is more recommendable K!ke |
