11/18/2013 10:24 PM | |
Joined: 3/14/2008 Last visit: 11/1/2024 Posts: 2121 Rating: (949) |
did you assign the AS and OS to your charts??? |
2/23/2016 8:58 AM | |
Joined: 1/17/2006 Last visit: 7/19/2024 Posts: 800 Rating: (63) |
Did anyone find the answer to this problem? |
2/23/2016 11:04 AM | |
Hello, About the internal error....Is the project created in a compressed folder? Please check the following: 1. Open windows explorer 2. Select the folder where the project is located 3. Open properties of the folder 4. Select General tab and then click on advanced 5. Deselect option: "Compress contents to save disk space" |
