9/20/2023 5:21 PM | |
Joined: 5/6/2022 Last visit: 9/29/2023 Posts: 293 Rating:
Hi PierreonimoDV, First of all, what I recommend is that you check the compatibility of your OS and the software you have installed. See it in the 'Compatibility Tool'. On the other hand, ask yourself the following: - Does this happen to you with any project? Can you try loading a very simple project and see if it has the same behavior? - I recommend that you try deleting the IM folder from the project, compiling and reloading to see if this improved the behavior. I share with you an FAQ that explains how to delete the IM folder: "How do I delete the IM folder from the TIA Portal project?": https://support.industry.siemens.com/cs/pe/es/ view/109778709 Best regards!
