6/1/2014 9:42 AM | |
Posts: 54 Rating:
Dear Mr.Pranav Thanks for your reply. Can you explain your statement in some detail, Actually I was also thinking the same but getting confused while implementing. I have attached the test program where I am making the changes and testing. Kindly see it and advice what should need to be changed. Thanks Raheel AttachmentAuto_cntrl_8_Pumps.zip (967 Downloads) |
6/10/2014 12:10 PM | |
Posts: 54 Rating:
Dear Jens Excuse me for my late come back, I was stuck in other works last days. I read the SCL code you send to arrange the pumps and assign the priority numbers from lowest to highest based on the Runtime calculation, I changed my block accordingly and used the WorkingTimes[0..7] array of Struct to start and stop my pumps but getting some errors specially in the "CASE" statement below the the code and please advice if something wrong. FUNCTION_BLOCK FB333 [snip] AttachmentFUNCTION_BLOCK FB333.txt (433 Downloads) |
