5/28/2007 4:26 PM | |
Posts: 1275 Rating:
Hi Leow, Using scripts to update tags may affect your performance in a negative way. In fact, the more scripts you have running, the more it'll affect the performance. You should whenever possible use tag update cycles. You can change the poll time for the tag update to increase performance. WinCC performance has been discussed many time at this forum. Please search for further information. Here are some of the previous threads: 1, 2, 3, 4. If after searching the forum you still have problems, please post. Best regards, Danielle |
