6/10/2010 10:29 AM | |
Posts: 63 Rating:
Dear ZUMA, You are not able to communicate your 313c using another port the only way to communicate by MPI cable From, Mayank Patel |
6/10/2010 11:32 AM | |
Joined: 5/28/2008 Last visit: 3/17/2025 Posts: 4518 Rating:
Hello ZUMA, You can use USB PC adapter 6ES7972-0CB20-0XA0. Connect it to the DP port and open Setting PG/PC interface in your PC and sellect PC adapter (profibus) or PC adapter (Auto.) It will work. Also if you have an external USBPromer 6ES7792-0AA00-0XA0, you can use it to downloading the the memory card directlly. Hope this helps. |
Ayman Elotaify |
6/11/2010 7:24 AM | |
Joined: 6/22/2009 Last visit: 7/24/2024 Posts: 44 Rating:
6/11/2010 11:55 AM | |
Hello, As UMENCHOmentioned in the previous post, installing of PC adapter is very important. Here's bellow the link of the PC adapter software: SIMATIC PC Adapter USB Software V2.0 Hope this helps. |
Ayman Elotaify |
