3/15/2018 12:49 PM | |
Joined: 4/28/2015 Last visit: 2/24/2025 Posts: 10832 Rating:
Hello, I recommend check system manual for general info about profibus network. You can also check web for general infos. Here is some list of topics where you can find some examples of users projects/problems, hope you can find some helpful infos for start to problematic (link): List of topics of Danfoss Profibus with S7-300 |
With best regards... |
3/15/2018 1:45 PM | |
Joined: 9/27/2006 Last visit: 3/17/2025 Posts: 12344 Rating:
Hello RAKIB; If you rquire basic information on Profibus-DP installation and network design, you could start with these documents::
https://www.profibus.com/download/profibus-installation-guidelines/
https://support.industry.siemens.com/cs/ww/en/view/35222591 Danfoss has setup its line of Profibus-enabled drives to follow the Profidrive profile, using PPOx telegrams, and PZD (Process Data) and PKW (Parameter value) sections of the Profibus telegram. This is very similar to the MM4 line of drives from Siemens. These sample programs may help you start on Profibus communications between a S7 CPU and a drive:
https://support.industry.siemens.com/cs/ww/en/view/8894584 Hope this helps, Daniel Chartier |
2 thankful Users |
4/3/2018 9:11 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by RAKIB is split to a separate thread with the subject What PPO should use to exchange data between s7300 and Danfoss fcd322 drive?. Best regards |
