4/18/2012 4:10 PM | |
Joined: 1/28/2009 Last visit: 2/21/2023 Posts: 6794 Rating:
[quote user="thomasy"] In SCL I would like to access data in data block from function. For example I have function "Scale", and few data block ("Axis1"," Axis2",...). I would like that input parameter of function is data_block, and that in function I could still access variables in symbolic format. For example: What is the difference in this case bettween BLOCK_DB and ANY type. Hello , About the data types (BLOCK_DB and ANY) , you can refer to chapter 7 of the following manual.(Sections 7.5 and 7.6). http://support.automation.siemens.com/WW/view/en/5581793 Best regards, Hamid Hosseini |
