1/3/2015 1:46 PM | |
Joined: 1/28/2009 Last visit: 4/22/2025 Posts: 6867 Rating:
Hello AutoGen_548322, Cells in any DB are global memories and can be access via variable operation in your program.You can write values from program , variable tables and HMIs.To globally access the DB,Assign a name to that in symbol table and access any cell with "Name of DB"."Name of Cell".In case of any access, use the correct syntax.Read more in the following link for initialization:
What is the significance of the initial and actual values of a data block? I hope this helps, Hamid Hosseini |
1/3/2015 2:16 PM | |
Posts: 784 Rating:
Hello, Perhaps the attached file might help. Best regards....
AttachmentData Blocks.pdf (148 Downloads) |
1/3/2015 4:16 PM | |
Joined: 10/23/2014 Last visit: 4/15/2025 Posts: 201 Rating:
thank you for you but how can i know the size (how many byte) of DB? |
1/3/2015 8:04 PM | |
this is photo (untitled3) |
