9/18/2013 4:57 AM | |
Joined: 1/28/2009 Last visit: 12/28/2022 Posts: 6785 Rating:
Hello, I suggest checking the following topic in the "STEP 7 Basic V12.0 SP1 (07/2013, English) " Manual.
Best regards Hamid Hosseini |
9/18/2013 5:27 AM | |
Hello, What do you mean by rge memory address? Cells in DBs are available in form of symbolic addresses and also absolute if you disable optimized access. Addressing variables in global data blocks I hope you don't mean the machine level addresses as discusses in old courses for Microcontrollers. Best regards Hamid Hosseini |
Last edited by: hdhosseini at: 9/18/2013 5:33 AMLast edited by: hdhosseini at: 9/18/2013 5:28 AM |
9/18/2013 6:10 AM | |
Posts: 4 Rating:
jajajajaja now i finally got it!!! i got confused the way you define tags with the input, output or memory address and prefix with the DB variables ... i thought i had to do the same but with the last link i understood it!!! thanks, you helped me a lot!!! [schnippschnapp] new question was splitted to Connecting to an S7-1200 via OPC and read/write values from/to DB |
