7/11/2011 5:39 PM | |
Posts: 621 Rating:
Dear all Tahnk you very much for the supporting the help. finaly i was get the result mean remove the bus fault now its working fine. now iamcommissioning the other panel same thing same problem.but here is a ABB DCS with Data exchange.but ABBDCS im not worked.in there Created AI 16 word and AO 32 word like wise the customer is asking to exchange the data between these to our plc SEND andRECEIVE. 1 fileattached here please check and suugeest or guideme. The main thing is that in ABB side they configured 16 word and 2 word.In my PLC software i configureDB101 and DB102.FC101 and FC 102. In FC 101 the pointer address P#DB101 DBx0.0 byte 32.out 2 is 1.while in FC102 the pointer address P#DB101 DBx0.0 4 byte out 2 is get 1. and its working fine the ABB DCS they made as word 32 more and I change in plc software FC101 pointer adress 32byte. while in FC102 i chnged 4byte to 16 byte 32 byte likewise. the out2 both function get 1to 0 friction of seconds happening and CP goes to bus fault mode.and i made db102 32 byte. so please give me the suggestion to rectfy the problem thanking you in advance algudkar Splitted from CP 342-5 bus fault system faulty. Attachment1233.zip (216 Downloads) |
7/12/2011 5:44 AM | |
Posts: 621 Rating:
Dear Wizard Thank you very much you are guided me to the regarding the CP. bus fault. that was finally a got the result as your and forum friends. again same anothe one panel im commissioning as attached below please guide me how to make DB lenth size to exchnge the 32 byte more then that ex every ting iwas explained to Umencho if possible read the thread and support me with best regards algudkar Attachment1233.zip (231 Downloads) |
7/12/2011 5:45 AM | |
Posts: 621 Rating:
Hi Hulzhex Thank you very much for the replay with best regards algudkar |
7/18/2011 6:57 PM | |
Posts: 621 Rating:
Hi dear wizard thank you as you suggested i have got some idea. thanks with regards algudkar |
