4/30/2014 7:50 AM | |
Posts: 1299 Rating: (136)
Hello, did you set the option "Enable logging at runtime start"? You can find the option either as a column in the table "Data logs" or in the properties of the data log in tab "Restart behavior". see also this faq: http://support.automation.siemens.com/WW/view/en/89855157 K!ke |
5/5/2014 8:42 AM | |
Hello, see this chapter in manual. K!ke |
9/21/2015 8:00 AM | |
Joined: 9/1/2005 Last visit: 12/19/2024 Posts: 4114 Rating: (195) |
New question published by Yazan_Jaber90 is split to a separate thread with the subject Comfort Panel: extract my logs and reports in a non adjustable form. Best regards |
