2/7/2018 10:27 AM | |
Joined: 4/28/2015 Last visit: 3/26/2025 Posts: 10837 Rating:
Hello, thnx for info again. Look, generally 'system of communication' is same on PLC side, you need call required instructions as you need. Other case are available data on Server/Slave. Devices can share different registers, addresses and this you need check in device documentation. Simply your code can be ok but if your Server not share data as you requested, you can't be lucky, you will receive error code which you need check. Also same problem is if you don't have connection with Server established. This can be also your situation f.ex. You need check output parameters as is described in manual, TIA help. In other case here is list of topics, you can check your solution (link): List of topics about MB TCP |
Last edited by: Duris_I at: 2/7/2018 10:30:11 AMLast edited by: Duris_I at: 2/7/2018 10:37:04 AMWith best regards... |
2/7/2018 1:34 PM | |
Posts: 3093 Rating:
Hello Aiyub, I recommend to look at this thread regarding error 8383. Regards, Kaulquappe |
2/8/2019 11:57 AM | |
Posts: 1 Rating:
Dear Aiyub, did you find the answer to this problem? I have the same problem in TIA portal V14 |
