1/14/2022 3:34 PM | |
Joined: 4/28/2015 Last visit: 8/12/2022 Posts: 2905 Rating:
Hi, that's not an off-topic :) There is many ways to store data on the IOT, using databases is the most common one, I guess. And InfluxDB is probably the most known timeseries database. As you said using the InfluxDB node in node-red could be the most easy way to achieve this. We have an example available with MariaDB, might be easy to change MariaDB to InfluxDB. Best regards! |
