2/27/2014 8:17 AM | |
Posts: 1368 Rating:
Hello, do you absolutely want to use PUT/GET or is the communication via open communication blocks (T-blocks) also a possibility? This is easy to configure and you do not need netpro. http://support.automation.siemens.com/WW/view/de/42361392/faq or here a faq to PUT/GET http://support.automation.siemens.com/WW/view/de/18610307 If you only want to tranfer cyclic data via profinet, you also can bind one IM as i-device to the other. |
