10/24/2007 10:52 AM | |
Posts: 27 Rating:
hi, i have almost same problem. wincc 6.0 was installed in my pc after i try to install wincc6.2. firstly i install sql 2005 without uninstall sql2000. when i install sql2005 its uninstall sql2000 and install finished. thaniinstall wincc6.2 without uninstall winnc6.0. afteriam continued to installpatch forwincc6.2 and simatic net for wincc6.2 . butwhen i try to open existing projectat wincc explorer it give me "Database context does not exist or is invalid"mesagge. what can i do? |
Last edited by: CS Moderator at: 25.10.2007 22:59new subject after splitting Last edited by: CS Moderator at: 25.10.2007 22:59 |
10/24/2007 12:33 PM | |
Posts: 1275 Rating:
Hi, Your project was created under v6.0, right? Did you migrate it before opening? Also... check out this FAQ. Best regards, Danielle |
10/24/2007 7:34 PM | |
Posts: 27 Rating:
i was restarted many times and problem is still continued. i have step 7 v5.4, step7-MicroWIN4.0 and 3.2, winccflex2005 and winccflex2005 RT, simatic net and sql MS sql server2005. all are licensed. this my"PMDiagnose.log" which is belong to my try to created newfile. 2007_10_16 13 13:47:35:312 CCProjectMgr.exe CSingletonProject::AttachDatabases pICCDBManagement->AttachDatabase \\BERKANT1\WinCC60_Project_aa\aa.mdf on BERKANT1 failed: 0x80040106 2007_10_24 13 13:56:35:562 CCProjectMgr.exe CSingletonProject::AttachDatabases pICCDBManagement->AttachDatabase \\BERKANT1\WinCC60_Project_asa\asa.mdf on BERKANT1 failed: 0x80040106 2007_10_24 15 15:46:11:859 CCProjectMgr.exe CSingletonProject::AttachDatabases pICCDBManagement->AttachDatabase \\BERKANT1\WinCC60_Project_asza\asza.mdf on BERKANT1 failed: 0x80040106 this my"PMDiagnose.log" |
10/24/2007 9:32 PM | |
Posts: 1275 Rating:
Hi, So you have Flexible in that computer.... Take a look at this compatibility matrix for Flexible 2005. Notice WinCC v6.2 isn't there... Best regards, Danielle |
11/9/2007 2:38 PM | |
Posts: 27 Rating:
my problem is still continue and i will be mad! i dowload my log file when i couldnt install sql server2005 AttachmentFiles2.zip (153 Downloads) |
