5/4/2009 8:22 PM | |
Hello, If you look in the chapter "requirements for use" of this manual http://support.automation.siemens.com/WW/view/en/27013386 you will see that you normally need at least - Step7 V5.4 SP4 - a cpu withFW of at leastV4.5 Do you fulfill these requirements? Special case: In the case of a spare part replacement, or if the functionality of the predecessor module or FW version is sufficient, configuration and diagnosis can also be done with earlier STEP7 versions. The CP can be configured as CP 443-1 (EX20) FW V1.0 |
5/12/2009 7:49 PM | |
Posts: 5 Rating:
Thank you very much, edr, that was the problem. Raul.
