6/25/2024 7:36 AM | |
Joined: 9/5/2022 Last visit: 7/9/2024 Posts: 4 Rating: (0) |
I tried to make it work on a MTP1000 but as I went to compile, it prompts an error: ,Object Member no válido: Database en fila 10, en columna 30,,,9:31:11 it seems like "Database" Object it's not available on MTP1000... why ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/25/2024 10:23:23New subject after splitting |
6/26/2024 4:24 PM | |
Hi, I attached a photo from HMI... I've tried to make a global function to do the select statement but it's impossible to import.... also I tried to do directly from snipped code... neither it works :-( ,it prompts that Database object doesn't exist... link to tia portal test file: [snip] CODE:
AttachmentHMI_SQL_v0.zip (76 Downloads) |
Last edited by: david_esteban at: 06/26/2024 16:28:30Last edited by: Jen_Moderator at: 06/27/2024 10:21:50Link removed and all files added as .zip file. |
6/27/2024 11:15 AM | |
Joined: 1/21/2013 Last visit: 9/11/2024 Posts: 3093 Rating: (482)
Hi David, I am sorry, but again I cannot reproduce your problem. I typed exactly what your screenshot shows and it worked fine. You might want to make sure that your system is up to date. Kind regards |
