4/10/2008 7:51 AM | |
Posts: 125 Rating:
Hi, I'm tested the connection OLE-DB to CSV, and its working without errors. Please check the correct Datasource -> WinCC-Project.xml. You can create it with "Project XML Export". There is an FAQ, who show the connection "WinCC - OPC to xls". Maybe this also helps you. http://support.automation.siemens.com/WW/view/en/26618193 Best regards |
4/10/2008 3:24 PM | |
Posts: 6 Rating:
That didn't work for me. |
