2/4/2021 2:39 PM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15318 Rating:
Hello cnmautonation if the Cycle is to slow you can also use Bittriggered Trends. Here is a FAQ (its for WinCC flexible, but you can also use it for TIA as well) https://support.industry.siemens.com/cs/ww/en/view/21913875 Unfortunately Datalogs of S71500 you cannot get into the Panel. Bye Murof |
