4/19/2012 12:39 PM | |
Posts: 36 Rating:
hello 1- I want to log some digital I/O and some analog inputs but i am unable to do it. i have attached here my program please help me to sort out my problem,there is 1 error in the program bt that will not affect the data log i think so. 2- I want to log data on event basis for my application of automationis it possible with 1200 n TIA PORTAL sp2. Pleasegive program examples regarding event based data logging. Attachmentdata log test.zip (79 Downloads) |
4/19/2012 7:33 PM | |
Joined: 9/23/2005 Last visit: 2/2/2023 Posts: 4177 Rating:
Hi, at https://www.automation.siemens.com/BR/tf/WW/en/Posts/57715#top, you have a example of data logging with word. you can adapt you to your necessity (for example copping the bool to the word). |
Denilson Pegaia |
4/19/2012 7:48 PM | |
Posts: 947 Rating:
You can use UDP protocol and use profinet port for logging data by ethernet application |
8/24/2014 8:29 AM | |
Joined: 9/1/2005 Last visit: 1/9/2023 Posts: 4097 Rating:
new question published by Motor-Mikeis split to a seperate thread with the subjectDataLogging problem - hangs after the first line. Best regards CS Moderator |
