1/28/2018 3:29 PM | |
Posts: 2 Rating:
Hi guys, I try to use the DataMan262 with a S7-1200 via Profinet. But I did not get any barcode data. I am a new user with the TIA Portal and SPS programming, so I have no idea how I can fix it. I program a small testprogram and try with it to read the DataMan. The DataMan is connected to the PLC and also in TIA Portal marked with a green dot. I program the DataMan as the manual of Cognex say it (there is an example). But I did not get any data. In the attachment you find my TIA Project. I hope someone can help me with this, because I have no idea and cognex support can not help me. AttachmentGewindeprüfgerätBasisTest.zip (221 Downloads) |
1/28/2018 3:58 PM | |
Joined: 5/6/2010 Last visit: 3/13/2025 Posts: 2012 Rating:
Hello WUMO, please look at this document: https://www.cognex.com/support/downloads/File.aspx?d=3004 There is a description to communicate with profinet (start at page 88), it's also available in german.. Hope this is helpful. regards |
1/29/2018 6:01 PM | |
Posts: 2 Rating:
thank you for helping. I know this document, and work with that. But it did not work. So i write here a topic. |
2/2/2018 8:15 AM | |
Posts: 1 Rating:
Hi Wumo, Am also facing the same issue . If you found any solution kindly share. Thanks, Vetrivel |
