2/9/2010 6:47 PM | |
Joined: 7/2/2008 Last visit: 3/14/2023 Posts: 928 Rating:
Hi Cheetos,Right if they are not marked Non Retain. You can find this check mark in the Data block object properties>General-Part 2. 1-You have tomake sure you need more than 2 Kbytes of retentive data for the CPU you have. 2- You can write to the MMC using SFC84 (Check this FAQ) but
Best regards. H-H |
3 thankful Users |
11/17/2016 12:20 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4812 Rating:
New question published by xmnj is split to a separate thread with the subject TIA, don't see a Object Properties. Best regards |
