1/21/2014 8:14 PM | |
Posts: 1 Rating:
Hi, I am having a problem with an 840C hyundia startup. The machine start bit when I press the power botton I have emergancy stop 2000 and 9000, no other errrors. I checked the I/R modual and according to a document I found the system healthy but I have no dc 24 volt on output 74 and 72 which say it is an internal relay. I can fix it myself but can't seem to find a replacement relay V23042-A2005-X071 would anyone know where to find this and is the attached file correct. Thank you all. Attachmentchecking procedure IR-FDD.pdf (49 Downloads) |
