4/29/2018 4:37 PM | |
Posts: 69 Rating: (4) |
Hello, How to connect the incremental encoder to dcm 6ra80 and how to check the feedback using starter software? |
4/29/2018 9:24 PM | |
Joined: 3/30/2011 Last visit: 1/18/2025 Posts: 736 Rating: (258) |
Hello
In DCM manual pag 114 you can see encoder connection at terminal 41-48
In the same DCM manual pag 273 you can see how to use starter to check encoder feedback you can use parameter r0061. Detail in list manual pag 753-754. Hope this helps, Best Regards |
Last edited by: mindware at: 4/29/2018 9:25:01 PMLast edited by: Jen_Moderator at: 4/30/2018 11:07:12 AMOptimized links. ★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★★ |
