12/4/2021 11:57 AM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating: (878)
Please refer below links to download Sinamics DCM GSD file. V 1.3 re.Version V 1.4. Service Pack 1 GSD PROFIBUS V1.4 SP1 (18,6 KB) re. Version 1.5. |
12/4/2021 12:00 PM | |
Joined: 4/29/2021 Last visit: 12/28/2021 Posts: 50 Rating: (0) |
Hai, Thanks for your quick reply. Im using profinet connection to PLC. Regards, |
12/4/2021 12:02 PM | |
In original post you asked for GSD file. However please refer below link. GSDML-File for PROFINET (all versions) |
12/4/2021 12:04 PM | |
Joined: 9/27/2006 Last visit: 12/4/2024 Posts: 12299 Rating: (2691) |
Hello Pulli Kutty; This link provides gsd files for different families of drives, including one link for your 6RAZ80XXX DCM units. https://support.industry.siemens.com/cs/us/en/view/98206128 The link will take you to a support document where you can download the gsd and gsdml files and also firmware downloads for Starter SSP, which you need to use in this type of project, to set the psrameters for your drives. The only Application Note for DCM drives can be found here, it includes a manual and different applucations that can help you out. https://support.industry.siemens.com/cs/us/en/view/103471886 Hope this helps, |
12/4/2021 3:04 PM | |
Hello Puli Kutty; Have a look at this FAQ, it guides you in selecting the partial part number (6RA8 0xx-xx) with the version of gsdml file you have integrated in your programming software. This can possibly help you out. https://support.industry.siemens.com/cs/ww/en/view/109783817 The following pages from the Sinamics DCM Operating Instructions discusses some issues of DCM control via Profinet. https://support.industry.siemens.com/cs/ww/en/view/109763558/106907891083 There are other sections in the navigation column at the lleft that can also help you, such as this one: Configuring a drive unit (with Starter). https://support.industry.siemens.com/cs/ww/en/view/109763558/107809532043 Hope this helps, Daniel Chartier |
2/28/2024 4:09 PM | |
Posts: 2 Rating: (0) |
SRA70 DCM DRIVE GSD FILE REQUIRMENT |
