11/24/2008 10:52 AM | |
Posts: 162 Rating: (23) |
Hi, No. The client PC and the server PC only work with the same local user account together. Then it goes. Best regards FrankW |
11/24/2008 11:23 AM | |
Hi, 2nd Solution: An OPC-Tunnel installed (but nit cheap), for example here: http://www.softing.com/home/en/industrial-automation/products/opc/easy-connect-suite/tunnel.php MfG FrankW |
11/25/2008 2:18 PM | |
Posts: 5822 Rating: (412)
Dear icarus, I guess the main problem is based upon the DCOM Configuration, isn't it? So why don't you use OPC UA? Check this: OPC Unified Architecture As far as I know is the OPC Server delivered with the latest Edition 2008 capable of providing OPC UA. Best regards J_Bell |
