3/9/2016 4:04 PM | |
Posts: 7 Rating:
Hi. I have almost the same problem here, instead that in my case, i couldnt solve it by installing the correct GSD. I have a Cognex DataMan 300 with the correct GSD imported in TIA Portal 13, everything OK until i want to define the I/O slots. Here in the picture i show whats happening. It seems that the I/O configuration is disabled, so when i go online i get the Error led blinking, just like happened with the other user. I think that is logical what is happening here, because i added a profinet node with an IP, but the PLC doesnt read a correct I/O mapping. So, the problem is that i cannot define this mapping. Any one knows how to enable it? I mean, how can i "drag and drop" the I/O modules in the configuration. Thanks very much in advance! ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 3/10/2016 4:40:49 PMNew subject after splitting |
