3/24/2022 1:47 PM | |
Joined: 8/3/2009 Last visit: 4/29/2025 Posts: 15380 Rating:
Hello GusoXXL you should not need a delay in a script if possible, because it blocks other scripts in the same script context. But If you need you can use the example from : LINK This works for mit in WinCC V17 Prof RT (waits for 5 sec.): ------------- Dim LastTime, StopTime, i ,DelayTime -------------- Bye Murof |
