1/26/2012 11:20 AM | |
Posts: 836 Rating: (100)
Hi, maybe "reset_wincc.vbs"can be tried first, but often it is not helping (in my case). |
6/9/2014 2:52 PM | |
Joined: 3/2/2007 Last visit: 1/22/2025 Posts: 967 Rating: (5) |
thank you sir, it works perfectly. |
... thank you ... |
6/11/2014 6:55 AM | |
thank you for your help. |
... thank you ... |
11/21/2020 6:14 AM | |
Joined: 9/9/2015 Last visit: 1/10/2025 Posts: 728 Rating: (283) |
The reason normally caused by running WinCC runtime (OS Server/WinCC application) using engineering station. The SQL archive will be generated in your project folder. when you deactivate, the services not being shutdown and still using by background processes. Normally engineering station should only do OS Simulation or OS Client runtime , but not OS server. |
Please give me 5 stars Rating if my post is helpful for you. :) |
