7/14/2008 6:28 PM | |
Posts: 2661 Rating:
In addition to deleting batch window (view3), you should change the view counter to 3 and rename view4 to view3 and re-attach TagPrefix direct connection. See attachment. Can you explain what you mean by this?. I agree it is best to place the comments in CFC. You can use string_0 or string_1 if BOOL and comment for others. Regards AttachmentBatchViewDelete.pdf (212 Downloads) |
7/15/2008 12:23 PM | |
Joined: 10/18/2006 Last visit: 7/29/2024 Posts: 163 Rating:
Hi Phantom, Thanks for the tips once again. Regarding the second topic, i found this, tested it and it worked properly... http://support.automation.siemens.com/WW/view/en/16626956 Cheers |
7/15/2008 6:26 PM | |
Posts: 2661 Rating:
Good FAQ. Thanks. |
