11/22/2016 7:00 AM | |
Joined: 5/12/2006 Last visit: 3/30/2023 Posts: 21352 Rating:
Hi, which Technical Data you need exactly? https://support.industry.siemens.com/cs/ww/en/view/21497504 from ordernumber you give: 15" TFT Keyboard / Color Display, 1024 x 768 Pixels Regards |
11/23/2016 7:10 AM | |
Joined: 6/28/2011 Last visit: 3/22/2023 Posts: 106 Rating:
Thanks Chistoph for yuor reply. Normally, i take the details of SIEMENS products from link https://support.industry.siemens.com/cs/?lc=en-US. But for this Panel PC, the website does not identify the part from its part number (6AV7803-0AB10-1AC0). The details I am looking for are, Product Life Cycle and Technical Data Sheet (In PDF). Also I want to know abiout the successor part. |
11/30/2016 11:14 AM | |
Posts: 648 Rating:
Dear kuttysk, the part number depends on the hardware configuration of your IPC677D. Do you know the TIA Selection Tool? There you can define your hardware configuration of IPC 677D and you will get the part number. http://w3.siemens.com/mcms/topics/en/simatic/tia-selection-tool/Pages/tab.aspx With best regards rh1990 |
11/30/2016 1:00 PM | |
Posts: 648 Rating:
Dear kuttysk, in the following you can find important information which helps to select and order the correct product: https://support.industry.siemens.com/cs/ww/en/view/75852684 With best regards rh1990 |
