8/31/2006 12:12 AM | |
Joined: 1/7/2006 Last visit: 12/23/2024 Posts: 2705 Rating: (320)
Hi Triodes, When you use Report System Error then the blocks are programmed by STEP7. Configuration of "Report system errors" and display in STEP 7 V5.1 There are also FB's and FC's programmed by Siemens that give you direct the missing station. PROFIBUS DP Diagnostics Blocks FB125, FC125 for SIMATIC S7 Good luck with this software... [;)] |
