12/21/2015 10:27 AM | |
Joined: 4/10/2006 Last visit: 6/5/2023 Posts: 817 Rating:
Hello, Ste39 you know the diagnostic repeater? i downloaded the manual but i don't understand what are the segment Dp1, Dp2, ecc Can you help me, please? thank you Roby ------------------------------------------------------------------------------------------ |
Last edited by: CS Moderator at: 12/22/2015 10:22:01 AMNew subject after splitting Setting of my PG M6 Siemens |
12/21/2015 10:49 AM | |
Joined: 1/21/2013 Last visit: 4/21/2023 Posts: 4617 Rating:
Hello Roby, Eh, so long ago, what you want to know exactly? If you want to use it as and if I remember correctly in the DP1 connect the Master unit and DP2 and DP3 do diagnostics segment, take a look at par. 3.1.7 on page 3-8 if you have downloaded this manual. Diagnostic Repeater for PROFIBUS-DP - Internet - Siemens |
12/22/2015 5:22 PM | |
Joined: 9/27/2006 Last visit: 6/5/2023 Posts: 12033 Rating:
Hello Roby; The information on diagnostics reading through the diagnostic repeater is available in the manual proposed earlier by Ste39. Alternatively, if you search the forum (see the Search Box at the right of this page?) you will find FAQs and Application notes that can further help you out. For example: Reading Diagnostic Information from the Diagnostic Repeater with STEP 7 and Methods for Remote Evaluation: https://support.industry.siemens.com/cs/ww/en/view/23328167 The Application Note uses a S7-400 CPU but states a “different CPU with DP interface and integrated SFCs 58, 59 and 103 can also be used.” Note: Based on the S7-300 Instruction List manual (https://support.industry.siemens.com/cs/ww/en/view/13206730 ,pages126 and 133) all three SFCs required are supported by the S7-315-2DP, so it can be used with the application proposed above. Hope this helps, Daniel Chartier |
12/23/2015 8:27 AM | |
Joined: 4/24/2006 Last visit: 6/5/2023 Posts: 8587 Rating:
Hello Roby, Please have a look at the following manual: System Software for S7-300/400 System and Standard Functions There is more information about the SFC's mentioned by Dchartier. You can find the SFC's in Library -> System library Best regards, Wizard |
