8/17/2021 12:19 PM | |
Joined: 8/2/2018 Last visit: 8/23/2024 Posts: 10 Rating: (0) |
Hi Wilson, The section is solution with Sinamics Inveters .Could not find the solution with 6RA80 Drive. Pls help if any further information is available for winder drives with 6RA80 Available. Regards sanjaya
Last edited by: Jen_Moderator at: 08/17/2021 13:07:02New subject after splitting. Inserted quote. Regards |
8/17/2021 1:19 PM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating: (880) |
Please check this manual, it is common for Sinamics inverter as well as for DCM. May help you. |
8/17/2021 1:22 PM | |
Joined: 10/11/2006 Last visit: 1/22/2025 Posts: 5985 Rating: (824)
Hello, the original answer is correct, please use the DCC application, it is for SINAMICS S120, S150, G130, G150 und DCM - and SINAMICS DCM is 6RA80. |
With best regards, |
