11/6/2014 5:42 AM | |
Posts: 1 Rating:
Hello, I want to know that is the cpu313c-2dp can be replaced by cpu313C.If possible then how can I do it.
11/6/2014 7:53 AM | |
Joined: 4/22/2010 Last visit: 2/26/2025 Posts: 5697 Rating:
Hello, The main difference is in the communication ports (DP), if you don't use these ports to control other equipment, you can maybe replace the CPU with a 313C, I say maybe because without partnumbers we can't really answer. There are many CPU 313C ,see here So pl;ease give us the partnumbers. Regards, Marcjan |
Problem solved? |
