6/10/2023 1:24 PM | |
Joined: 9/27/2006 Last visit: 9/15/2024 Posts: 12282 Rating: (2683) |
Hello Sarvar_uz; What CPUs are you wrking with? As you can see from the attached screenshot, developpers of the S7-300 family used DO for digital ouptut module definition, whereas the newer s7-1500 uses DQ for the same type or digital output module. Just a marketing designation issue, all Siemens S7 output modules work in a similar fashion across different families. By following theis link to the Simatic Industrial Mall, you will be able to examine the same for analog output modules of different S7 families. https://mall.industry.siemens.com/mall/en/ca/Catalog/Products/10204173?tree=CatalogTree Hopethis helps, Daniel Chartier |
